94 Stron V  « < 15 16 17 18 19 > »
> Black Devil Corsa A 3.0 N/A 343 KM 343 NM
specu
post Thu, 26 Aug 2010 - 13:11
Post #321
A ja wiem że nie smile.gif i np w Dajtkach jest dużo lepszy
Chester
post Fri, 27 Aug 2010 - 10:15
Post #322
ZEGRZE 21.08 :
2.063 (best) czasy w przedziale 2.06-2.2
[1] RT 0.709, 60ft 2.078, ET 13.046 @ 177.19 KPH [2] RT 0.720, 60ft 2.096, ET 13.047 @ 177.53 KPH
[3] RT 0.667, 60ft 2.123, ET 13.141 @ 175.36 KPH [4] RT 0.612, 60ft 2.167, ET 13.233 @ 175.02 KPH
[5] RT 0.628, 60ft 2.136, ET 13.241 @ 175.40 KPH [6] RT 0.706, 60ft 2.114, ET 13.172 @ 174.44 KPH
[7] RT 0.692, 60ft 2.060, ET 13.208 @ 174.85 KPH [8] RT 0.668, 60ft 2.104, ET 13.251 @ 175.48 KPH
[9] RT 0.705, 60ft 2.143, ET 13.223 @ 176.29 KPH [10] RT 0.792, 60ft 2.075, ET 13.155 @ 175.06 KPH
[11] RT 0.754, 60ft 2.081, ET 13.202 @ 174.35 KPH [12] RT 0.666, 60ft 2.127, ET 13.316 @ 173.81 KPH
[13] RT 0.630, 60ft 2.155, ET 13.358 @ 175.99 KPH [14] RT 0.752, 60ft 2.112, ET 13.261 @ 176.25 KPH
[15] RT 0.719, 60ft 2.103, ET 13.298 @ 174.73 KPH [16] RT 0.720, 60ft 2.125, ET 13.314 @ 176.03 KPH
[17] RT 1.128, 60ft 2.077, ET 12.918 @ 177.75 KPH [18] RT 0.910, 60ft 2.141, ET 13.245 @ 175.06 KPH
[19] RT 0.890, 60ft 2.183, ET 13.281 @ 174.10 KPH [20] RT 0.731, 60ft 2.204, ET 13.452 @ 173.90 KPH
[21] RT 0.761, 60ft 2.172, ET 13.443 @ 174.14 KPH [22] RT 0.766, 60ft 2.129, ET 13.450 @ 174.39 KPH
[23] RT 0.967, 60ft 2.063, ET 13.265 @ 174.23 KPH [24] RT 0.719, 60ft 2.103, ET 13.600 @ 168.06 KPH
[25] RT 0.649, 60ft 2.270, ET 21.929 @ 52.00 KPH
PRUSZCZ 24.07:
2.269 (best) czasy w przedziale 2.26-2.6
[1] RT 0.707, 60ft 2.367, ET 13.495 @ 171.97 KPH [2] RT 0.734, 60ft 2.342, ET 13.648 @ 172.87 KPH
[3] RT 0.747, 60ft 2.373, ET 13.661 @ 171.65 KPH [4] RT 0.874, 60ft 2.269, ET 13.543 @ 169.97 KPH
[5] RT 0.735, 60ft 2.499, ET 13.729 @ 172.46 KPH [6] RT 0.760, 60ft 2.346, ET 13.771 @ 170.85 KPH
[7] RT 0.611, 60ft 2.367, ET 13.949 @ 170.17 KPH [8] RT 0.783, 60ft 2.526, ET 13.856 @ 173.52 KPH
[9] RT 0.735, 60ft 2.363, ET 13.949 @ 170.93 KPH [10] RT 0.772, 60ft 2.373, ET 13.990 @ 171.33 KPH
[11] RT 0.718, 60ft 2.558, ET 14.178 @ 171.61 KPH [12] RT 0.843, 60ft 2.427, ET 14.063 @ 174.19 KPH
[13] RT 0.861, 60ft 2.381, ET 14.092 @ 170.33 KPH [14] RT 0.747, 60ft 2.528, ET 14.208 @ 170.85 KPH
[15] RT 0.956, 60ft 2.496, ET 14.172 @ 170.49 KPH [16] RT 0.666, 60ft 2.596, ET 14.570 @ 170.81 KPH
[17] RT 0.910, 60ft 2.596, ET 14.340 @ 172.62 KPH [18] RT 0.866, 60ft 2.414, ET 14.641 @ 167.09 KPH
KĄKOLEWO 27.06 (zapewne jeszcze z c20xe):
2.126 (best) czasy w przedziale 2.12-2.32
[1] RT 0.683, 60ft 2.126, ET 13.671 @ 165.54 KPH [2] RT 0.638, 60ft 2.247, ET 13.905 @ 157.04 KPH
[3] RT 0.655, 60ft 2.180, ET 13.894 @ 162.05 KPH [4] RT 0.755, 60ft 2.184, ET 14.004 @ 162.09 KPH
[5] RT 0.915, 60ft 2.205, ET 13.921 @ 161.52 KPH [6] RT 0.980, 60ft 2.273, ET 14.307 @ 157.95 KPH
[7] RT 0.967, 60ft 2.226, ET 14.850 @ 158.64 KPH [8] RT 0.630, 60ft 2.321, ET 25.381 @ 53.08 KPH
[9] RT 0.658, 60ft 2.204, ET 28.402 @ 37.14 KPH
KAMIEŃ 30.05:
2.145 (best) czasy w przedziale 2.145-2.377
[1] RT 0.652, 60ft 2.377, ET 13.899 @ 164.57 KPH [2] RT 0.729, 60ft 2.203, ET 14.002 @ 163.50 KPH
[3] RT 0.760, 60ft 2.223, ET 14.038 @ 162.16 KPH [4] RT 0.964, 60ft 2.175, ET 13.932 @ 162.99 KPH
[5] RT 1.129, 60ft 2.200, ET 13.952 @ 162.78 KPH [6] RT 1.456, 60ft 2.145, ET 13.934 @ 162.88 KPH
BEMOWO 25.04:
2.141 (best) czasy w przedziale 2.141-2.56
[1] RT 0.862, 60ft 2.440, ET 14.166 @ 167.44 KPH [2] RT 0.795, 60ft 2.562, ET 14.496 @ 167.09 KPH
[3] RT 1.162, 60ft 2.141, ET 14.164 @ 165.96 KPH [4] RT 1.053, 60ft 13.317, ET 31.493 @ 83.79 KPH
Pomimo tego że auto gorzej jeździło, nigdzie nie robiłeś takich czasów na 60FT jak ostatnio, więc jeśli chodzi o nawierzchnię to chyba temat jasny, tym bardziej że wszyscy piszą że przyczepność była bardzo dobra.
Ecu-Tune.Pl
ade
post Fri, 27 Aug 2010 - 10:23
Post #323
a ja tak wracajac do tytulu tematu, jaki najlepszy zmierzony czas i moc na c20xe??
specu
post Fri, 27 Aug 2010 - 10:33
Post #324
CYTAT(Chester @ Fri, 27 Aug 2010 - 10:15) *
ZEGRZE 21.08 :
60 ft były na silniku 2.0 z 1 biegu ,a teraz na silniku 3.0 z 2 biegu
CYTAT(ade @ Fri, 27 Aug 2010 - 10:23) *
195 zmierzone przy 6800 potem co widać wykres poszrpany... Moc nie zmierzona na trąbkach bo awarie awarie awarie... Best 13.67 Kąkolewo , jak się okazało później latałem na popsutym ECu Det III
waszka
post Fri, 27 Aug 2010 - 13:59
Post #325
Złe dobrego początki smile.gif Wygląda na to,że ogarnąłeś kłopociki i zacznie się pobijanie własnych rekordów.Tak trzymaj i czekam aż pęknie 12 s wink.gif
Nauka jazdy,przygotowywanie do KJS/OES - /Tor Kielce,Ułęż,NMnP/ - pisać PW ;)
pol
post Sat, 28 Aug 2010 - 08:56
Post #326
CYTAT(K@rol @ Wed, 25 Aug 2010 - 15:56) *
czas do 100kmh robi wrazenie, podobno Polo Pola (20vt) robi 4.15 do 100kmh ciekawa konfrontacja by byla.
mozemy sie konfrontowac , u mnie co prawda tylko 1.8 ale daje rade tongue.gif
ET 11.40 Polo 1.8t
2010 1st fwd turbo drag
Drag Racing Team Wroclaw
klima
post Sat, 28 Aug 2010 - 23:43
Post #327
CYTAT(Chester @ Wed, 25 Aug 2010 - 11:29) *
Czym mierzyliście czas do 100km/h ?
złomowanie pojazdów-recykling
sląskie i opolskie-odbiór własnym transportem
auto handel,auto czesci,pomoc drogowa
NowmaRacing
605829000
guzior
post Sun, 29 Aug 2010 - 00:49
Post #328
klima
zapewne to wiesz co. Pomiar z zawodow, jakis TAG czy inne ustroistwo
885 60 50 40
gość_k-meal_*
post Sun, 29 Aug 2010 - 17:08
Post #329
CYTAT(guzior @ Sun, 29 Aug 2010 - 00:49) *
klima
to tag pokazuje czas 0-100?
2m-garage
post Sun, 29 Aug 2010 - 19:47
Post #330
specu, a latasz na pospawanym dyfrze ??? ja jak pospawałem dyfer w kadecie to sprężgło poprostu sie rozpadło i wypadło dołem przy chińskich oponach 205
klima pw nie dotarło???
guzior
post Sun, 29 Aug 2010 - 20:38
Post #331
nie wiem co pokazuje, ale specu mial pomiar 0-100 z zawodow na jakich pojechal 12,9
Dyfer jest zaspawany, sprzeglo dziala.
885 60 50 40
klima
post Sun, 29 Aug 2010 - 20:56
Post #332
jezdziłem tyle razy na przerózne imprezy i nigdy nie dostałem pomiaru 0-100 angry.gif
NowmaRacing
605829000
specu
post Mon, 30 Aug 2010 - 08:13
Post #333
Znajomy pożyczył takie ustrojstwo... Racelogic czy cos? Ruszyłem idealnie bez zbytniego pisku (ulica) , potem porównałem na g-tech (miarodajnie 1/4 12.85)i wyszło 4.12 do 96 wink.gif
Co do sprzęgła, jest to seria z półki, nie oryginał i daje rade od wczesnej wiosny mimo ze kiedyś dostało oliwy na tarcze...
kosiniak
post Mon, 30 Aug 2010 - 22:38
Post #334
CYTAT(waszka @ Fri, 27 Aug 2010 - 14:59) *
a to nie pekla juz? cos mi sie wydawalo ze widzialem strone wczesniej 12,9? smile.gif szybka ta twoja corsa smile.gif
klima
post Mon, 30 Aug 2010 - 23:56
Post #335
CYTAT(specu @ Mon, 30 Aug 2010 - 08:13) *
NowmaRacing
605829000
specu
post Tue, 31 Aug 2010 - 07:35
Post #336
CYTAT(kosiniak @ Mon, 30 Aug 2010 - 22:38) *
Kamilbike
post Wed, 01 Sep 2010 - 08:51
Post #337
2m-garage wez pod uwage ze corsa jest sporo lzejsza od kadeta i to to pewnie pomaga w tym ze sprzeglo nie wychodzi bokiem
waszka
post Wed, 01 Sep 2010 - 17:02
Post #338
Ja pisałem o złamaniu 12s a póki co pękła 13....
klima
post Wed, 01 Sep 2010 - 21:05
Post #339
CYTAT(waszka @ Wed, 01 Sep 2010 - 17:02) *
NowmaRacing
605829000
specu
post Thu, 02 Sep 2010 - 15:57
Post #340
Muszę ogarnąć drag slicki coby przenieść moment na drogę...
Odwiedziłem dziś hamownię i seria po wystrojeniu przez Śpiącego Ekumasterem na rolkach pokazała całkiem przyjemne cyferki
RSS Wersja Lo-Fi Aktualny czas: Thursday, 06 November 2025 - 08:57
