> S4 AGB?? Przeplywka??, co z moja S4??
kosiniak
post Tue, 29 Apr 2008 - 19:29
Podpial mnie kolega dzis i o to co wyskoczylo, co robic? co wymieniac? czego szukac?? itd.?? Dodam ze auto jakis slabo jedzie, i przy 5krpm ewidentnie brak mu sily i jakby przerywa, na dzien dzisiejszy nie wymienialem nic bo czekam na wstepna diagnoze, po wekendzie wymieniam plyny i filtry, na co jeszcze zwrocic uwage??
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 00529
3 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D26
Coding: 04395
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 N
Component: A4 KLI
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 930 Q
Component: B5-KOMBIINSTR. VDO D05
Coding: 00162
Shop #: WSC 00000
˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ AUZ7Z0X1125945
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 13131
Shop #: WSC 06325
1 Fault Found:
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06325
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00012
Shop #: WSC 06325
End -------------------------------------------------------
J@RO
post Wed, 30 Apr 2008 - 06:43
Address 01
3 Faults Found:
P1128 - 35-00 - -
P1130 - 35-00 - -
Address 35
Coding: 13131
Shop #: WSC 06325
1 Fault Found:
00956 - Key 2
To sa twoje bledy...NAUCZ SIE WSTAWIAC LOGI -> POLOWA RZECZY JEST OK! (No fault codes)
czyli po edycji to:
17536 P1128 Długoterminowy pomiar paliwa – system za słaby (bank 1)
17538 P1130 Długoterminowy pomiar paliwa – system za słaby (bank 2)
16514 P0130 Obwód czujnika O2 – usterka (bank1 czujnik 1)
00956 - Key 2 -> oznacza blad sterownika komfortu - cos nie teges z kluczykami do auta.
teraz tak, wyglada na to ze gdzies masz rurke peknieta i ci popuszcza boost (17536 & 17538). Sprawdz czy system trzyma cisnienie - to jest pierwsza rzecz jaka sie robi w turbo audi. Mysle ze jak uszczelnisz system to auto nabierze wigoru wink.gif Jezeli jednak to nie pomoze a auto trzyma cisnienie w systemie to prawdopodobnie bedzie to wina MAFa...
kosiniak
post Wed, 30 Apr 2008 - 08:38
CYTAT("J@RO")
dokladniej to co to ten MAF??
eMeM
post Wed, 30 Apr 2008 - 08:44
przeplywomierz
kosiniak
post Wed, 30 Apr 2008 - 09:05
czyli nic z lambda jak to kots zauwazyl na innym forum? czy trudno powiedziec? ok sprawzdam doladowanie i szukam nieszczelnosci
kosiniak
post Tue, 24 Jun 2008 - 16:58
wiec uklad cisnienie trzyma, mechanicznie auto tez jest sprawne w 100%, jak sprawdzic reszte? zaznaczam ze nie mam o audi zielonego pojecia!
kosiniak
post Wed, 25 Jun 2008 - 15:02
odpialem przeplywke i auto sie odpycha, moze nie tak jak powinno choc nie jezdzilem wczensiej s4 ale jest ok smile.gif dziwi mnie tylko ze bez przeplywki jezdzi lepiej niz z nia?? rano faluja obroty, na vagu pokazalo lambde, czy molziwe ze to grzalka??
Norbi1
post Wed, 25 Jun 2008 - 20:40
Wymień przepływkę. W ASO to chyba niecałe 4 stówki.
Jak sprawdziłeś czy układ trzyma ciśnienie?
[b]RS4[/b]
kosiniak
post Thu, 26 Jun 2008 - 02:06
nie ja to sprawdzalem, sprawdzal to mechanik a jak to tego nie wiem, wlasnie sie zastanawiam czy kupowac to w ASO czy kupic w IC i wymienic samemu? chyba nie robi to roznicy poza tym ze bdzie minimum 100pln w kieszeni?
Gr00bY
post Thu, 26 Jun 2008 - 02:16
Jesli kupisz boscha/pierburga czy inne ustrojstwo co było oryginałem to nie bedzie różnicy.
WORKSHOP
kosiniak
post Thu, 26 Jun 2008 - 07:52
o tym wlasnie myslalem smile.gif ktos moze wie jaki powinna miec numer/symbol?? tak sie zastanawiam bo moze moja poprostu jest nie taka jak powinna byc i dlatego jest problem?? auto jest z 99' AGB
pavel
post Thu, 26 Jun 2008 - 08:22
CYTAT(kosiniak @ Thu, 26 Jun 2008 - 07:52) *
ktos moze wie jaki powinna miec numer/symbol?? auto jest z 99' AGB
078 906 461
zaciski hamulcowe BREMBO-renowacja-lakierowanie proszkowe-adaptery do zacisków BREMBO-serwis rajdowy RPP/RSMP/GSMP
Gr00bY
post Thu, 26 Jun 2008 - 08:48
W intercarsie brak biggrin.gif Pytaj gdzie indziej...
WORKSHOP
Norbi1
post Thu, 26 Jun 2008 - 17:28
Jak oddasz swoją do ASO to dostaniesz zniżke. Nie kombinerkuj , bierz z ASO.
Musisz wymontować przepływkę z tym kawałkiem rury w której jest osadzona.
[b]RS4[/b]
kosiniak
post Fri, 27 Jun 2008 - 00:09
sklepy tez daja znizke jak oddaje stara przeplywke no i przepywki sa ori
kosiniak
post Sun, 29 Jun 2008 - 12:48
ostatecznie wzialem w ASO smile.gif dzikei panowie, dalbym wam po pochwalce ale nie ma jak smile.gif
Norbi1
post Sun, 29 Jun 2008 - 16:08
Pomogłlo?
[b]RS4[/b]
kosiniak
post Sun, 29 Jun 2008 - 20:52
RSS Wersja Lo-Fi Aktualny czas: Saturday, 04 October 2025 - 09:45
