303 Stron V  « < 17 18 19 20 21 > »
> ecumaster - zrob to sam
IceMan
post Sat, 20 Sep 2008 - 22:08
Post #361
też tak wpisałem ale niestety wskazania roznia sie od tych z notebooka (podlaczony przez port szeregowy do lc1) i to dość znacznie
126p -> escort xr3 -> escort 1.6i -> golf3 tdi -> fiat qpe 20vt -> s13 -> s14 -> s14a
Jadzwin
post Sun, 21 Sep 2008 - 00:23
Post #362
Najpierw ustalcie co macie na wyjsciu z innovate.
Z manuala
To log analog outputs from the LC-1 into an LM-1, simply connect analog output #2 (brown wire)
to an available input on the LMA-2 (RPM converter Aux. In Cable) or LMA-3 (5-sensor “AuxBox”).
Set LogWorks inputs match the LC-1 outputs. As discussed in section 7.6 above, factory settings
for the second output is programmed where 0V=.5 (AFR of 7.35 for gasoline) and 5.0V=1.523
(AFR of 22.39 for gasoline).
Jezeli macie zmienione parametry na wyjsciu bedzie inne napiecie.
Ewentualni moze wystepowac ponizszy problem:
Sometimes there is a ground offset between the device that receives the analog output voltage
and the LC-1. This can be especially true if the System ground is not connected to the same
ground as the measurement device using the analog out. Both devices reference different
grounds and therefore see different voltages. So to compensate for the ground offsets the analog
output voltage points have to be shifted by the ground offsets. To measure what the real ground
offset is, you can program the analog outputs temporarily to output a flat line voltage by entering
the same voltage in both fields for the two analog out programming points. This way the analog
output voltage will be fixed, independent of current AFR and can therefore be measured and
compensated for easily.
Pozdr
Jadzwin
IceMan
post Sun, 21 Sep 2008 - 08:41
Post #363
w parametrach lc1 nic nie tykałem i jest jak z fabryki
więc pozostaje mi z masą powalczyć
Zibi122
post Sun, 21 Sep 2008 - 20:57
Post #364
CYTAT(IceMan @ Sun, 21 Sep 2008 - 08:41) *
Wejdz w paramety LC-1 i ustaw ze afr 10 - 0V a 20 to 5V i po sprawie. Tam masz wyjscia które sa programowalne i nie musisz tak kombinować.
Mam LC-1 i podłaczyłem go tak do ECUMSTERA jak rówież do MegaSquirta i wszystko elegancko działa.
jarek111
post Sat, 27 Sep 2008 - 14:14
Post #365
pytanie w logach linie czasu co ile s są
calibra turbo EDS phaze2 1\4starachowice 13,58
kansai
post Mon, 06 Oct 2008 - 17:38
Post #366
który firmware najlepiej dziala z s13 ca18det z waszych doswiadczen?
Śpiący
post Tue, 07 Oct 2008 - 00:13
Post #367
Panowie, napotkałem strasznie uciążliwy problem.
Mianowicie gdy w kliencie klikam na ai1, ai2, lub ai3 (analog input) wyskakuje mi windowsowski komunikat w stylu "program wykonał niedozwoloną operację i zostanie zakończony" (czy jakoś tak), zdaża się też że klient wyłącza się bez żadnego komunikatu. Pod analog input 3 podłączyłem sonde szerokopasmową (LC-1).
Nie mam pojęcia co jest nie tak, sprawdzałem na wersji klienta 1.1 i 1.0q, firmware 1.73_60_2, system operacyjny: Windosw XP, przejścówka USB->RS232.
DET2 podłączałem i stroiłem koledze dzień przed wyścigami, nie wyszła nam idealnie konwersja MAF->MAP i "przyszedł" nowy dolot. Auto domagało się dostrojenia, ale z racji niemożliwości pokrycia mapy AFRem i przede wszystkim braku czasu wystroiłem to na podstawie logów (oczywiście zegara do LC-1 nie było i tylko jedna przejściówka USB-RS232), przy mniejszych obciążeniach trzeba jeszcze dostroić (najlepiej jutro) i stąd prośba o porade co zrobić żeby dało się poktyć mapę AFRem.
Było: Łada 1.3 turbo-nitro, Ibiza FR TDI + GTB.
Jest: Corsa C 380KM/420Nm + Zafira B OPC (jeszcze seria).
artix
post Tue, 07 Oct 2008 - 09:31
Post #368
CYTAT(Zibi122 @ Sun, 21 Sep 2008 - 20:57) *
moglbys wrzucic jakas rozpiske jak podlaczyles LC do DET.a
E36 coupe M50b28 T by Artix
Jadzwin
post Tue, 07 Oct 2008 - 10:35
Post #369
Spiacy: Ten problem jest juz rozwiazany, nie ma nowego softu na stronie. Dzisiaj wieczor podesle ci linka do wersji z ktora nie bedziesz mial problemow.
Co do nissana to wysarczy firmware 1.51.
jadzwin
Zibi122
post Tue, 07 Oct 2008 - 12:49
Post #370
CYTAT(artix @ Tue, 07 Oct 2008 - 09:31) *
Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR. Note: The LC-1’s heater ground and system ground wires should share the same
grounding location of the analog input’s ground.
Czyli brązowy z LC-1 to OUTPUT 2. Jest domyślnie ustawiony jak widać powyżej.
Musisz w LM Programer zmienić te ustawienia na 0V = 10AFR 5V=20AFR
W ECU pod pin 10 - Analog IN #3 podłaczasz ten brązowy przewód od LC-1 i w zakładce setup ładujesz skale WIDE BAND SENSOR AFR 10-20
I tyle.
Śpiący
post Wed, 08 Oct 2008 - 17:40
Post #371
Jadzwin: co z tym linkiem?
Jadzwin
post Wed, 08 Oct 2008 - 20:21
Post #372
Soft zapodany na strone www.ecumaster.com
Bezposredni link:
Client for windows 1.12
Milego strojenia.
Jadzwin
integrali
post Mon, 13 Oct 2008 - 10:42
Post #373
Witam posiadam auto leciwej daty ktore odbudowuje pochodze z warszawy czy jest jakis posiadacz sady szerokopasmowej.
Kosiarz
post Mon, 13 Oct 2008 - 12:49
Post #374
a jest mozliwosc dostania kabelka do ecumastera pod usb ?? bo mam ten starego typu ale moj laptop nie ma takowego slota
Fuel Games Part I am 21.05.2011 Rothenburg 1/4 ET 13,6 SCIERWOLOT
https://picasaweb.google.com/112471818709940932677/SIERRACOSWORTHKOSIARZ
http://www.youtube.com/user/Kosiarzzz
http://tnij.org/cosworth Mój projekt
Jadzwin
post Mon, 13 Oct 2008 - 13:01
Post #375
Konwerter USB -RS232 bedzie dzialal. Jedyne co to musisz go ustaic tak zeby com byl pomiedzy com1-com8.
Prolific RS232 - USB converter
CYTAT(Kosiarz @ Mon, 13 Oct 2008 - 13:49) *
Kosiarz
post Mon, 13 Oct 2008 - 15:36
Post #376
no dzieki za odpowiedz :-)
graluCT
post Fri, 17 Oct 2008 - 16:56
Post #377
pytanie na poziomie przedszkola ale mnie nurtuje...
sterowanie zapłonem -> "wartości ujemne w komórkach mapy opóźniają zapłon"... to opóźnienie jest w wartości kąta wyprzedzenia zapłonu czy w stosunku do położenia tłoka?? angielskie określenie jest proste advance (wiecej przed GMP), retard (mniej przed GMP)...
jak to jest w ECM?? dając wartości dodatnie w mapie przyspieszamy zapłon (wieksza wartość przed GMP) czy opóźniamy (mniejsza wartość przed GMP)??
Jadzwin
post Fri, 17 Oct 2008 - 17:12
Post #378
Retard ed - opozniony zaplon (wartosci ujemne na mapie)
Advanced - przyspieszony (wartosci dodatnie na mapie)
CYTAT(graluCT @ Fri, 17 Oct 2008 - 17:56) *
graluCT
post Fri, 17 Oct 2008 - 18:57
Post #379
dzieki jadzwin
skoro tu juz jestem to powiedz mi z jakiej zaleznosci wyznaczane sa wartosci AFR (AnIn3), które można nałożyć na mapy fuel/injection?? Czy są to bezpośrednie wartości z loga czy jakieś wartości uśrednione z mapy korekcyjnej??
Pytam dlatego, że nawet na postoju, po wkreceniu silnika w daną komórkę pojawia mi się jakaś tam wartość AFR (powiedzmy 17) -> koryguję wartość paliwa do poprawnej dawki i na mapie korekcyjnej pojawia się rzeczywista aktualna wartość AFR (przyjmijmy 12.8), natomiast w komórce mapy głównej z nałożonym AnIn3 albo pozostaje stara wartość bez zmian, albo po odświeżeniu inna wartość niż na mapie korekcyjnej...
wiem tylko tyle, że czyszczenie loga czyści też AnIn3...
tak ma być czy coś nie halo z moim ECM??
ewentualnie jakie wskazania AFR są najbardziej wiarygodne w panelu DETII (log, mapa korekcyjna, dyno, itp), wg których powinienem się kierować przy strojeniu??
pozdrawiam Cie serdecznie
Jadzwin
post Fri, 17 Oct 2008 - 20:12
Post #380
Ogolnie wykorzystanie pkrywania map AFR wygalda tak:
1) Czyscisz log
2) Robisz przejazd testowy w interesujacym cie zakresie obrotow/obciazem
3) Nakladasz AFR na komorki
4) Dokonujesz poprawek
5) Idziesz do punktu 1
Mapa pokrywana jest aft na podstawie calej informacji z loga. Aktualna informacja o AFR jest albo w komorkach Real Time Loga w zakladkach z mapami, albo na logu (aktualnie logowana wartosc).
Jadzwin
RSS Wersja Lo-Fi Aktualny czas: Friday, 07 November 2025 - 08:04
