Civic Si / swap z ITR 2003 |
Mon, 13 Oct 2003 - 23:38
Frequent User Dołączył: Wed, 07 May 2003 Skąd: Warszawa |
Silnik:
HONDATA ECU Upgrade (Dyno- 212 wheel hp /149 ft. lbs. Torque-gained 30hp in mid-range) MUGEN N1 Stainless Race Exhaust System with Header AEM Cold Air Intake AEM Hi-Flow Fuel Rail MUGEN Reservoir Covers MUGEN Thermostat MUGEN Fan Switch SPOON 65mm Throttle-body SPOON Magnetic Drain Plugs (oil pan and transmission) FEEL'S Oil Cap J's Racing Engine Torque Dampner VISION Carbon Fiber Valve Cover Insert CUSCO Oil Catch Can HYPERGROUNDS (grounding system) EARL'S Steel-braided Fuel Line T-1R Mini Dry-Cell Battery with Custom Mounting Kit DENSO Iridium Spark Plugs HASport Motor Mounts Top Fuel Power NEO (fuel atomizer) Zawieszenie i kola: VOLK Racing CE-28N 18 x 7.5 +45 (GOLD) NITTO Neo Gen Tires 215/40-18 TEIN FLEX Coil-over system with Pillow Mounts/Camber Kit TEIN EDFC (Electronic Damping Force Controls) VOLK Racing Aluminum Wheel Locks (black) MUGEN 25mm Rear Sway Bar NEUSPEED Front Lower X-Brace Mr. Alex Front & Rear Strut Bars SPOON Rear Lower Tie Bar -------------------- Sprzedam nerkę.
Mon, 13 Oct 2003 - 23:49
Forum Killer Dołączył: Sun, 20 October 2002 Skąd: Wuwua |
fajne ale jakies osiagi before after and after tjuning seryjna ITR silnika
-------------------- Byl Cif Teraz Jest Golfina SOHC 8v 1.4 60KM ...
Tue, 14 Oct 2003 - 09:59
Forum Clubber Dołączył: Tue, 12 November 2002 Skąd: Wołomin |
CYTAT MUGEN AEM AEM MUGEN MUGEN MUGEN SPOON SPOON FEEL'S VISION CUSCO HYPERGROUNDS EARL'S DENSO HASport VOLK NITTO FLEX TEIN EDFC VOLK MUGEN NEUSPEED Mr. Alex SPOON
Tiaaaa.... jeszcze brakuje OMORI i HKS do kompletu najdroższych producentów, ale pewnie tylko zapomnieli podać. -------------------- dragracingowy spiker do wynajęcia ;)
Tue, 14 Oct 2003 - 10:16
Forum Clubber Dołączył: Fri, 18 October 2002 Skąd: Warszawa |
CYTAT("Marlon":3j6fyw8l) CYTAT MUGEN AEM AEM MUGEN MUGEN MUGEN SPOON SPOON FEEL'S VISION CUSCO HYPERGROUNDS EARL'S DENSO HASport VOLK NITTO FLEX TEIN EDFC VOLK MUGEN NEUSPEED Mr. Alex SPOON Tiaaaa.... jeszcze brakuje OMORI i HKS do kompletu najdroższych producentów, ale pewnie tylko zapomnieli podać. akurat to nie są jakieś wybitnie drogie firmy drogie są: Top Secret, Jun, Endless, Defi, Magneti Marelli i ewentualnie Blitz BTW. nie wiem czemu ma służyć ten topic -------------------- whatever
Tue, 14 Oct 2003 - 11:01
no dokładnie, obrazek i jakies tam literki. Mamy od samych nazw dostać orgazmu czy jak?
Tue, 14 Oct 2003 - 11:49
Zbiorowy onanizm surowo wzbroniony.
-------------------- Wojtek
Wersja Lo-Fi | Aktualny czas: Saturday, 27 April 2024 - 16:55 |
