Pompa Wody Elektryczna, Davies Craig |
Tue, 15 Jun 2010 - 22:30
Super User Dołączył: Tue, 15 July 2003 Skąd: Katowice |
Nowa, nieuzywana, do mocno modowanych silnikow, znakomicie dziala niezaleznie od obrotow silnika.
oryginalny opis: "The revolutionary EWP pump from Davies Craig is made from anti-corrosive, lightweight, glass-filled nylon & incorporates a carbon mechanical face seal for added reliability. The EWP improves engine cooling control and capacity while giving you more power & improved fuel economy. The EWP is universal and fits almost all makes of vehicles on the road today. This EWP80 version is suitable for most vehicles with small to mid capacity engines, eg 4 to 6 cylinder engines. The benefits of fitting a Davies Craig EWP over an existing mechanical pump are - * Coolant is circulated after engine shutdown preventing hotspots * Increased engine power and torque * Better control of engine temperature * Increased cooling capacity * Improved fuel econmy * Increased engine life * Radiator size and coolant capacity can be reduced saving weight * Increase in maximum engine speed Davies Craig EWP pumps can be fitted as a stand alone item, however to obtain the full benefits it is recommended that it is used with a digital controller which gives you full control over the engine running temperature. Kit includes a selection of fittings to suit different hose sizes and installation instructions." cena 499zl posiadam rowniez niezalezny sterownik wentylatorow: "This dual digital controller from Davies Craig allows you to control your electric water pump and radiator fan in one unit. Simply set the optimum engine running temperature and let the digital controller adjust the coolant flow rate accordingly, locking onto your target temperature. Should the temperature rise 3 degrees above the target then the controller will automatically switch on the radiator fan until the temperature is reduced. A further feature is the ability to run the water pump for 2 minutes after the engine is shut off, reducing heat soak and prolonging engine life. Your engine is also able to reach optimum temperature faster reducing cold start engine wear. The EWP/Fan controller has a range of onboard diagnostics which can analyse and report the state of your cooling system." cena 399zl |
Wersja Lo-Fi | Aktualny czas: Thursday, 25 April 2024 - 09:08 |
