E64 nie odpala ... |
Thu, 27 Sep 2018 - 18:20
Forum Killer Dołączył: Mon, 19 December 2005 Skąd: Płock |
witam, jest tak pacjent 645ci , po włożeniu kluczyka do stacyjki na blacie pojawia się zółtego koloru ikonka z rysunkiem kluczyka i ...koniec no i nic i nie odpala :Dktos ma jakiś pomysł ? samochód stał dwa dni ojciec chciał przestawić i takie kwiatki , aha aku naładowane klemy docisniete ..
Thu, 27 Sep 2018 - 18:37
Forum Killer Dołączył: Wed, 13 August 2008 Skąd: Bratislava |
-------------------- Blog Motoryzacyjny TorquedMad mind - tqmm.pl
Thu, 27 Sep 2018 - 18:52
Bio - link nie hula nie wiem czemu :/ edit :link działa , jutro wymieniamy bat. w kluczyku zobaczymy czy cos pomoze...
Fri, 28 Sep 2018 - 18:58
Masz Ctrl+C > Ctrl+V
CYTAT Problem
BMW may show the key symbol on the instrument cluster and car won't start. The key may have a slash, line or exclamation line on top. In some cases, you will have a key symbol and Park showing on your instrument cluster at the same time. This means that the BMW is not recognizing the key which could be due to several reasons as outlined below. If you try to push the Start button, you get this warning lamp and nothing happens. BMW won't start or turn over. The vehicle is not recognizing the key which could be due to several reasons. If BMW yellow key warning light displays when you are driving it is because the car stopped recognizing the key in the cabin. This can be due to the key being physically removed from the car or a problem with the comfort access. If you don't have the key and turn off the igntion, you can restart your BMW by pressing Stop/Start button within 10 seconds after the car has been shut off. Even if there is no key in the cabin. Symptoms Causes Possible Solution Back to top 1. SYMPTOMS BMW will not start or turn over Yellow key warning light on instrument cluster BMW PARK warning light on Car or Instrument Cluster doesn't turn on Key symbols come up while driving Back to top 2. CAUSES Defective BMW key Comfort access not working Low battery voltage Electrical interference Water in BMW keyfob Local radio waves Back to top 3. POSSIBLE SOLUTION STEP 1 Replace the batteries in your key fob. If you have comfort access the batteries may be dead. If that is the case, your BMW will not recognize the comfort access key. Follow the instructions on this guide to learn how to replace BMW key fob batteries. A temporary solution would be to start the car by inserting the key into the key slot. If your BMW has Start/Stop button, you will need to hold the key next to the steering column where you see a small key symbol. Some BMW models have a slot where you can insert the key for a manual start or press the key against the Stop/Start button. STEP 2 Try another key. There is a very good chance that the BMW key fob has failed. If you have a second key, try starting the car with it. If the car starts and runs fine with the other key, then the first key fob is defective. STEP 3 If your BMW key fob got wet because you washed it or let it out in the rain, it can fail to communicate with your BMW. Let the BMW key fob dry for a few hours and try again. If a BMW got wet, it may stop working. Even if the key starts to work again, you shouldn't rely on it as it may stop working at any time. STEP 4 Check the age of the main battery on your BMW. If the battery is over 7 years old, replace it even if you think you don't need a new battery. BMWs are very sensitive to the battery and voltage drops. A low battery can cause electrical issues including the key to not be recognized by the ignition. Follow this guide to learn how to replace BMW battery. Rember to perform battery registration as outlined in the tutorial. STEP 5 If your BMW still won't start or turn on, it is time to get a diagnostic scanner and read the codes. A generic OBD2 scanner will not help you much, but a BMW specific scanner will be able to read BMW specific codes. -------------------- Blog Motoryzacyjny TorquedMad mind - tqmm.pl
Thu, 04 Oct 2018 - 19:21
Kluczyki sprawdzone i okazało się ,ze sa sprawne , winowajca był padniety aku (niestety samochód był u rodzicow i ojciec tego nie wyłapał )musiałem szybko wylecieć do nl .. cos zaczęło zrec tak prąd ,ze po 3 dniach padł i dlatego choinka na desce rozdzielczej , wróce z Amsterdamu to spróbuje zdiagnozować co się stało bo dziwna akcja...
Wed, 10 Oct 2018 - 13:19
Pewnie czytnik navi albo klema pirotechniczna.Częste awarie w tych modelach.
Thu, 11 Oct 2018 - 14:24
Navi bylo niedawno naprawiane bo wyswietlacz sie wykrzaczyl a z klema to jak zdjagnozowac czy to tu problem?
Thu, 11 Oct 2018 - 14:38
Nie wiem jak w E64, ale w E39 i innych z tego okresu jest tzw. jeż i on potrafi rozładować akumulator. Objawy to m.in. samoczynne włączanie się nawiewu nawet jak nie ma kluczyka w stacyjce, także zmieniająca się siła nawiewu pomimo braku jej zmiany na panelu i inne wariacje.
-------------------- Sprzedam części do E36, E39.
Thu, 11 Oct 2018 - 23:01
Podpinajac + do aku troche sie iskrzy pomyslalem ,ze moze przez oswietlenie bagaznika ... sa jakies sprawdzone testery? czy kupowac inpe z laptopem czy jechac do "the besciaka w okolicy " co za kasavje bledow bierze 200?
Wersja Lo-Fi | Aktualny czas: Thursday, 25 April 2024 - 07:00 |
