Big Block Chevy - 572 ci + 8-71 blower | 1000+ HP |
Sun, 17 Oct 2021 - 17:53
User Dołączył: Thu, 13 February 2014 |
Patrze jakie jest zainteresowanie - chętnie się pozbędę i do budowy kolejnego draga zakupie cos mocniejszego.
Jak sie nie sprzeda to pojezdzi ze mna na poczatku dla wczucia sie w nowego dragstera, choc wolalbym juz pojsc w cos bardziej w klasyce hemi tylko pod drag. Ten silnik to tak naprawde mocny streetowy dzik a nie czysto dragowy. Grzeczny, da sie w korkach jezdzić i na 1/4 także trochę zamiesza. Cena 65K PLN - do rozsądnej negocjacji - dalem za bestie duzo wiecej, ale tak to juz jest Silnik od rozebrania Paradoxa jest schowany w magazynie cieplutkim bez wilgoci. 3-4 x w roku wlewam do cylidrow odrobine oleju i przez chwile recznie krece silnikiem zeby wszystko bylo git. Film z dyno - https://www.youtube.com/watch?v=v_97ImX0exQ Wrzucam opis po angielsku z ogloszeń na innych grupach. It was used just for few months in my 79 Camaro. Just a tad on the street - maybe 30-40 km and 4-5 trips to the dragstrip ( well airstrip to be precise ). With bad traction it finally did 10.9 and is capable to do low 9 or high 8 in lighter car and prepped track. And you can still drive it on the street Just check valve lash every 1500-2000 miles It is almost as brand new. Build in the States by Precision Race Engines it has cost me more than 30K EUR I'm selling because I need cash for my 57 belair project, and later on I'm building a full Comp ET dragster that needs a bit different engine by FIA regulations. I'm still reluctant on the sale - it's hard to part with such great powerplant. I just want to keep it - but I don't think I am able to afford it all at the same time. So the price is negotiable - but just a tiny bit. If it wont sell for that I will put that to good use later on for sure. 1020 horsepower @ 6800 RPM and 854 ft lbs of torque @ 5100 RPM Spec New Dart Big M 4-bolt splayed main block • Bore 4.630" for 572ci your choice! • Torque plate honed (represents head being torqued to block) • New Durabond Coated cam bearings installed • New Brass freeze plugs installed • All New oil galley plugs installed • Painted with High Heat Paint (orange) Rotating assembly • Callies/Compstar 4340 Steel 4.250" stroke crankshaft • Callies/Compstar 4340 Steel H-beam 6.385"rods (ARP 2000 Bolts) • Clevite Race Series Hardened Rod & Main Bearings • MAHLE 4.630" Forged Dome Pistons • Pro Plasma Molly rings • All Rods big & small ends and Pistons machined to same weight • Rotating assembly balanced to race specs with printed spec sheet(.02 of oz. inch or within 2 grams) Pro-Filer Sniper X CNC Ported Cylinder Heads • 119cc combustion chambers • 345cc intake runners • Bronze valve guides • Hardened valve seats • 2.300" and 1.880" Stainless Steel valves • Matching springs,Titanium retainers,and hardened keepers to camshaft • Pocket Porting & Polishing • Flow Tested 412cfm intake 293cfm exhaust • ARP Head Studs Camshaft specs • Comp Cams Solid Roller Custom Blower Cam • Crower Sever Duty Roller Lifters ( a must with solid street applications) • T&D Shaft Mounted Roller Rockers • Smith Brothers 3/8" Chrome Molly hardened pushrods • Engine Works Billet True Double Roller timing set w/ torrington bearing Fuel System • Two Quick Fuel 950cfm Blower Carburetors • Dyer Polished 8-71 Blower Kit • Dyer Carb Linkage • Dyer Carburetor Fuel Line Kit Also included • March Style Track Corvette serpentine kit with p/s,alt.,& a/c installed. • Moroso 7qt 9" deep stroker oil pan • Moroso Oil Pump Pickup • Melling High Volume oil pump • Melling Hardened oil pump shaft • Comp Cams Roller Cam Button • Comp Cams Cam Locking Plate w/150,000 psi bolts • Fel-Pro Multi Layered Steel Head Gaskets • Fel-Pro Timing Cover Gaskets & Rear Main Gasket • Fel-Pro Intake Gaskets • Fel-Pro 1 piece Oil Pan Gasket • CHEVROLET slant style Aluminum Tall Valve Covers (orange or black available,polished extra) • MSD Pro Billet Distributor • Polished Billet Aluminum timing cover • Pro Race Double Keyed Blower Harmonic Balancer • Billet Aluminum adjustable Timing Pointer • Mr Gasket Chromoly Balancer Bolt • All new stainless steel oil pan,timing cover,& intake bolts • Engine makes 1020 horsepower @ 6800 RPM and 854 ft lbs of torque @ 5100 RPM making 4.7lbs boost( On 93 octane pump gas) • With pulley change at 5.6lbs boost engine make over 1070hp This engine is Dyno Tested and run through the break in process.We will have the carburetors jetted & tuned in with the correct timing set. -------------------- 1979 Camaro Z28 572ci - _PARADOX RACING FACEBOOK
Wersja Lo-Fi | Aktualny czas: Wednesday, 24 April 2024 - 00:21 |
