Chyba nie było:
![]() ![]() ![]() ![]() ![]() ![]() The guys from Essen DieselTuning, in the Netherlands, are known for working on diesel engines tuning but also for developing technological innovations for the racing track. But they do also some extreme engine tuning if customer wants it! Because the knowledge and the ability of mechanical tuning is still present at Wim Essing, they decided to do an extreme project, an Audi RS-6 with a standard capacity of 580 hp upgrade with both mechanical tuning and software tuning to: 950 hp @ 6900 Rpm & 965 Nm @ 6800 Rpm. This project has a total of 3 weeks work duration. The whole engine was out before they could adjust the mechanical parts. The RS-6 engine an impressive look, judge for yourself! udi RS-6 Engine mechanics: To reach this kind of extreme power, there was a lot of mechanics EDT had to process. 2 x Garett competition ball bearing turbo’s 230.000 Rpm Compression ratio decreased Watercutted cylinderhead gasket stainless steel ECU remapping via CMD in 7 stages Competiton exhaust 2 x K&N sportairfilter 2 x cylinderhead “geflowed” & re-shaped 2 x racing katalysts superflow 20 competition valves extra Ceramic breakes. Field Data after tuning: Acceleration 0 – 200 Km/h : 9,158 sec. (0 – 125 MpH : 9,158 sec.) Fuel consumption under full throttle: 43 L/100 Km Top speed : Calculated 380 – 400 Km/h (236 – 249 MpH), (not tested)[hr] ![]() P.S. Sorry jeżeli nie ten dział... -------------------- #włoszczyzna
![]() Super User Dołączył: Sat, 12 January 2008 Skąd: Białystok ![]() |
Nie no grubaśnie
![]() -------------------- Kszzzzysztof
![]() Forum Killer Dołączył: Tue, 27 March 2007 Skąd: Gliwice/Rybnik ![]() |
Film chyba nie pokazuje ani połowy możliwości.Bo czas 140-200 to około 7s, więc bez rewelacji jak na taką motorownie. Chyba, że jechali na pół gwizdka
-------------------- 200KM/290Nm/1088kg
Frequent User Dołączył: Sat, 13 December 2008 Skąd: Poznań ![]() |
imponująco płaskie kreski
tez za bardzo nie wiem po co pokazywali zegary skoro tam sie nic nie dzialo
![]() ![]() -------------------- 2011 - 20vt 635km/725nm by DIGITUN
![]() Super User Dołączył: Sun, 29 December 2002 Skąd: Trójmiasto ![]() |
slabo dawali mu w palnik, a czasu 0-100 nie podadza? przeciez to pewnie ze wzgledu na naped katapultuje sie masakrycznie, trakcje ma caly czas, ciekawe czy robi okolice 3s.
-------------------- Pozdrawiam,
Maciek |
Super User Dołączył: Sun, 12 June 2005 Skąd: Warszawa ![]() |
Na filmie nie wygląda na 950KM, chyba, że nie cisnęli ostro.
![]() Super User Dołączył: Fri, 26 November 2004 Skąd: Warsaw ![]() |
Ciekawe co na to skrzynia......
Na filmiku gość mówił, że jeździ to RS6 na doładowaniu 1,9Bar
-------------------- Audi 20V Turbo Quattro
Ciekawe co na to skrzynia...... Może własnie dlatego nie pokazali 0-100 i lekko depcza na elastyczności ![]() -------------------- 5L -> 5P // 30 6L 120
H 3P 20 1L # 80 4-P |
![]() Super User Dołączył: Sun, 13 January 2008 Skąd: Poznań ![]() |
Słooooodko.....
User Dołączył: Sat, 09 August 2008 ![]() |
gość_Pablo vel 2hot_* |
![]() ![]() ![]() ![]() A tak na marginesie a Ty ile masz? ![]() Odnośnie modyfikacji RS6 - 950KM to naprawdę solidny wynik, ale nie wiem czy ma sens w tak ciężkim aucie. Czy będzie takie przełożenie na osiągi w porównaniu z bardziej przystępnymi modyfikacjami w granicach 700-750KM. Film dużo nie pokazuje, może będzie więcej. Pozdr. |
to tak na marginesie 260KM,ale na 910kg
![]() Forum Killer Dołączył: Tue, 29 October 2002 Skąd: Wlkp. ![]() |
I z miejsca masz dużo gorszy współczynnik masy do mocy od RS6 z tematu
![]() -------------------- BMW
Każdy wie ,że sprzęgło w tym aucie to kicha,na 100%nie przeniesie tej mocy... i ja to wiem,a zresztą nie bede się sprzeczał o coś co jedzie gorzej niż zwykły rs6
Więc od razu Ci napiszę,że tych prawdziwych KM ma góra 800KM-nie do wykorzystania przez systemy i przód napęd ![]() Co Ty pier...sz? Jaki przód napęd? Podejrzewam że nawet zwykły MTM 730KM by zrobił z Ciebie wiatrak ![]() -------------------- www.audiklub.org
Pozdrawiam Mirek |
gość_gucior_* |
Każdy wie ,że sprzęgło w tym aucie to kicha,na 100%nie przeniesie tej mocy... i ja to wiem,a zresztą nie bede się sprzeczał o coś co jedzie gorzej niż zwykły rs6 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Zrób wszystkim przyjemność i idz już sobie stąd, please. |
sa jakies modyfikacje zeby skrzynie wzmocnic?
bo to troche nie za dobrze jak jest tyle mocy ktorej w sumie nie da sie calkowicie wykorzystac. no chyba ze do top speed. -------------------- <b>wtryskiwacze: BOSCH 525cc wysokoomowe, Bosch 650cc, SIEMENS 630cc 1200cc Lucas niskoomowe</b> |
Zrobię tobie przyjemność i pozwolę Ci się rozkoszować RS6 co nie jedzie...
Wersja Lo-Fi | Aktualny czas: Wednesday, 24 September 2025 - 01:50 |
