> Przekladka skrzyni z automata na manula lexus is200/300
Cookee
post Wed, 12 Aug 2009 - 12:49
Witam sprawa wyglada nastepująco po przekladce silnika z 2l na 3l 2jz-ge chcialem przelozyc skrzynie na manualna gdyz IS300 wychodzily na automatach problem polega w tym ze trzeba zmostkowac kable w kostkach (2) by oszukac kompa i ustawić go w pozycji P, wiazka pochodzi z lexusa IS300 i silnik tez wiec do skrzyni automatycznej wchodzily 2 kostki w starszych typach silnikow 2jz-ge byla to jedna kostka, czy wie ktos moze ktore kable trzeba zmostkowac bodz czy ktos ma jakis manual wiazki do lexusa prosze o pomoc pilne:)
Joker
post Wed, 12 Aug 2009 - 14:47
CYTAT(Cookee @ Wed, 12 Aug 2009 - 12:49) *
rzadkość ale wychodziły też w manualu
BeeMiX
post Thu, 13 Aug 2009 - 02:38
WIRING
this is for '01's. I'm almost certain that this is not the same for '02+ IS's (mainly since our '01 IS's draw a speed signal from the ABS, so nothing needed to be wired for that :-)).
There will be 3 plugs that you unplug from the auto tranny. One of them will have 9 wires coming out of it. THIS IS THE ONLY ONE YOU NEED TO MESS WITH. If I remember correctly, the wires come out of some little circles, some are smaller circles (yellow ones), some are larger circles(red ones).
:::For the starter, take the two wires coming out of the 2 larger red circles (its a solid black wire and a black/white wire), cut them and splice them TO EACH OTHER.
:::For the reverse lights to work, my tranny had two wires coming out of the side, a red one and a white one. on the SAME plug where you spliced the two black wired, there will be two red wires. splice these two red wires to the two wires coming out of the tranny (this may be different depending on which R154 you get and what condition its in. unfortunately i can only contribute how my specific wire setup was.)
*if for any reason your wires are different colors or your IS is a different year, all we did was hook up a multimeter to the battery and stuck the little probe into each hole until the reverse lights came on.
AND YES, WHEN I PUT THE CAR IN REVERSE, THE LITTLE "R" IN MY DASH LIGHTS UP ORANGE LIKE IT USED TO, WHICH IS SWEEEET!!
z ciekawości, modzisz coś w aucie czy tylko wymiana skrzyni?
98 Smaragd schwarz SL500
08 S500L
Cookee
post Thu, 13 Aug 2009 - 12:26
Tak przekladka na 3l i zamierzam uturbić.. tak jak to zrobiła pewna osoba z wawy... wszystkie prace będą szły w kierunku driftu zobaczymy co z tego wyjdzie:) dzieki za odpowiedz
BeeMiX
post Thu, 13 Aug 2009 - 14:17
ale które 2jzge wrzuciles? Chyba nie z vvti?
08 S500L
Cookee
post Thu, 13 Aug 2009 - 21:32
a dlaczego? vvti jakoś mniej wytrzymują?
saleen
post Thu, 13 Aug 2009 - 21:58
Tia, słabsze korbowody
EDIT: hmm. a może jednak nie tongue.gif mógłby ktoś kompetentniejszy ode mnie wypowiedzieć się ws. tych korb w 2jz?
Bardzo wiele osób powtarza/powtarzało że vvti = słabsze korby - ale czy ktoś tego w końcu nie obalił? Pewien nie jestem.
Cookee
post Thu, 13 Aug 2009 - 22:07
a ktoś sprawdzal ile wytrzymuja moze nie sprawdzal ale gdzies wyczytał?
BeeMiX
post Thu, 13 Aug 2009 - 22:45
z tego co ja wyczytałem to przekraczanie ~350KM robi się trochę niebezpieczne
08 S500L
BeeMiX
post Fri, 14 Aug 2009 - 03:14
Tak na szybko http://my.is/forums/f114/2jzgte-piston-309526/
08 S500L
RSS Wersja Lo-Fi Aktualny czas: Wednesday, 30 April 2025 - 08:40
